Possible to view multiple monitors at the same time but zoomed in?
bailey
bailey Posts: 4
edited April 2021 in General questions
Exactly as the title says: Is it possible to view multiple monitors at the same time but instead of both being squeezed onto the screen, but to have them zoomed in and then you can scroll accross the screens like it does with **third party content**?
  • Chiron
    Chiron Posts: 229 ✭✭
    Once you are connected, check the view options at the top of the window.
    • Monitors are NOT in individual tabs
    • The correct number of monitors are displayed at once
    • Scaling is original
    I couldn't get the window to follow my mouse. I had to scroll using the bars on the bottom and side.
