Unable to connect to Macbook Pro from Windows 10
Miket1948
Miket1948 Posts: 2
When connecting to Macbook Pro Teamviewer reports that Macbook is running an older version and says an update is required. Both the Windows machine and the Macbook are running the latest version of Teamviewer 14. The Macbook can take over the Windows PC but not the3 other way around.
    Hello @Miket1948,
    I've sent you a private message regarding your question.
  • Miket1948
    Miket1948 Posts: 2
    I've checked my spam folders and I have not received the personal reply mentioned by JeanK
  • Natascha
    Hi @Miket1948
    Thanks for getting back.
    Can you please check directly here in the community if you received any message in your inbox?
    In the upper right corner, next to your user name you will find the inbox:2019-07-05 08_12_25-Reply to Message - TeamViewer Community.png
    Hope this could help.
    Wish you a nice day and all the best,
    Natascha
  • rhelou
    rhelou Posts: 1
    Does anyone have a solution for this?
