Disable "Remote Control Using Password" Feature
Is it possible to disable the "Remote Control Using Password" feature in TeamViewer 12?
You want to block all incoming connections?
Or you want to connect, but not need a password?
I don't work for TeamViewer. I'm just a user.0 -
Thanks for your reply.
I want to just restrict the users to allow themselved to connect to their work PCs using their home PCs.
When you add a device under the list of "My Computers", and you keep your session open in your Work computer, when you go home and use your Home Computer, login to Teamviewer, you would see the Work Computer you've added. There is an option (2nd option) to connect using "Remote Control Using Password". I want to be able to disable this option globally, perhaps through a GPO? Is this at all possible?
I think you can do what you want using a whitelist, but I'm not sure it can be done with Group Policy (Active Directory). If you have a coorporate TeamViewer license you may be able to setup a policy (under Design & Deploy).
Black and Whitelist
