Uninstallation of Teamviewer not possible
i´ve tried to uninstall TV14 which was rolled out via msi (script). There was a previous tv-installation (i guess 13) which is causing trouble.
I´m currently unable to uninstall tv via Uninstall/Programs or via msiexec shell. I´m getting error 1603 in uninstallation. When i use graphic interface via Software Teamviewer 14 is listed but cannot be uninstalled (uninstallation is immediately rolled back).
I´ve also tried to delete the software manually - without luck. I´ve deleted the necessary strings in the registry.
What to do?
Kind regards,
Simon-Timothy
Same issues. Bump
Tried this solutions same issue.
https://community.teamviewer.com/t5/TeamViewer-14/TeamViewer-14-fails-to-uninstall/m-p/49634#M211
This finally worked, I had tried the previous suggestions but this was the one thing that actually worked. Thanks!
2 -
The level of skill is **bleep** too high! ??
Thank you guys for sharing your solution(s) and knowledge. ?
Dude if I could buy you a beer I totally would, this script saved my bacon again today. I pushed it out to the rest of my team! Thanks again!!!
This one worked for me too, cheers guys!
