command line (grant-easy-access)
verasmeat
Posts: 2 ✭✭
Hello everyone, tell me please, we use TeamViewer with the functions of the "grant-easy-access" on client computers
how to connect to the client computer using the command line, when we are using -i parameter, a password prompt appears, although if you try to connect from the application, the connection is made without asking for a password?
Same Issue here.
I know that this is an old post, but just in case someone else is looking for the answer:
start explorer "teamviewer10://control?device=YourIDhere"
1
