How to get assignment working with mass deployment?
We are using a trial of TeamViewer corporate license and have been unsuccessful in getting TeamViewer to assign to our account with Easy Access with a script. I have looked at the KB articles online and nothing so far has worked.
This is the script.
msiexec.exe /i TeamViewer_Host.msi /qn CUSTOMCONFIGID=IDGOESHERE APITOKEN=APITOKENGOESHERE ASSIGNMENTOPTIONS="--alias %COMPUTERNAME% --grant-easy-access"
Also tried this.
msiexec.exe /i "C:\Temp\TeamViewer_Host.msi" /qn CUSTOMCONFIGID=IDGOESHERE
ping -n 31 127.0.0.1>nul
"C:\Program Files (x86)\TeamViewer\TeamViewer.exe" assign --api-token=APITOKENGOESHERE --grant-easy-access
No luck. I've spent a good day or two trying to get this working. Am I missing something here?
    Hello @StRosesIT,
    I can confirm that the script you are using is correct. ✅
    I recommend trying with an other module (and therefore a new CUSTOMCINFIG and a new APITOKEN.
    Sometimes it resolves the issue...
    Let me know if this has helped!
    JeanK
  • StRosesIT
    StRosesIT Posts: 2 ✭✭
    Hi JeanK,
    Thanks for the advise, sadly I tried this a few times and it still doesn't work.
  • Hi, we have the exact same problem with a corporate demo license.
    On a PC where the script was not working, I tried to assign it manually.
    From that moment, if I uninstall Teamviewer from this PC and reinstall it using the initial script it works and assigns it automatically.
    Clearly I can't do manual assignment for all the PCs I need. So I would like to understand how to proceed to make the assignment from the first launch of the script.
    Do you have any advice?
    @RobertoBianchi
    Have you tried to use a newly created module?
