Teamviewer Crashes
Mushi_Mushi
Mushi_Mushi Posts: 1 Newbie
edited February 2022 in General questions
Hello!
I've been using teamviewer for the last 2 weeks, but as of recently (starting monday and today it is wednesday) my teamviewer crashes on the computer I wish to controll. I controll my PC at home from work through my phone I usually connect to my PC after letting my PC stay on for about 5-6 hours. I open an application and it crashes, and it used to work fine but not since the start of this week. I don't get any error messages or anything at all, teamviewer crashes and on my phone it says that this PC is offline, even though when I go home whatever application I open will be on but teamviewer is gone.
Is this a common problem? Anyway to solve it? I tried reinstalling on both my mobile device and my computer, this did not solve the problem.
    JeanK Posts: 6,852 Community Manager 🌍
    Hello @Mushi_Mushi,
    I hear about crashes every now and then...
    Many crashes are due to OS ⟺TeamViewer version incompatibilities.
    Maybe you can check if the device you are using is compatible with the TeamViewer version that is installed:
    You'll find the list here:
    /JeanK
    @Mushi_Mushi Have you managed to sort your crashing issues out? Did you check the compatibilities?
  • trmil
    trmil Posts: 3 ✭✭
    hi i am running the latest version of teamviewer 15.43.3 with windows 10 version 22h2 x64. according to the supported operating systems i should have issues however my teamviewer crashes daily on my remote control end. the windows just close out and disappear and i have to reload the client. i am not sure what else i can do please let me know how i can solve this issue
  • trmil
    trmil Posts: 3 ✭✭
    edited September 7
    Thank you for the response! may i ask what you make of this event viewer description? cheers
