Disable sending all keys via shortcut
Jelitek
Posts: 1 ✭
in Linux only
Hi everyone, I need to disable sending all keys to the remote machine by a key combination.
I need to do this on Ubuntu 20.04 and Debian 9.
If it is not possible to do this directly on teamviewer, a script would be also good.
Thank you.
I have the same request, but I am on Fedora 34 with KDE 5.22.5 . Did you find any solutions?
Since the sending ctrl+alt+delete is not supported via keyboard input, maybe we can find a work-around with that as a starting point.
