Sound on both computers
When i listen to music connected to another computer the sound comes out both devices. how can i control the sound so that it ony comes out on the destination computer. thank you
  • headydad
    headydad Posts: 2
    found the settings! thank you anyways
  • susieqk
    susieqk Posts: 4
    can you share your solution? I have the same issue. I don't want to hear destination computer's music when connected. Thanks!
  • DomLan
    DomLan Posts: 490 ⭐Star⭐
    Hi @susieqk,
    maybe this:
    (you need to disable that check)
    Domenico Langone
    MCSD: App Builder
  • susieqk
    susieqk Posts: 4
    Where do I find "Options"? FYI: I have the free version so I do not have access to all areas of the Teamviewer service areas, I do not know if that is why I do not see  "Options".
  • DomLan
    Extra -> Options
    Domenico Langone
    MCSD: App Builder
  • susieqk
    susieqk Posts: 4
    Where is "Extras" located?I don't see "Extras"I don't see "Extras"
  • DomLan
    Please, open your local TeamViewer client.
    Domenico Langone
    MCSD: App Builder
