Failed to fetch URL while Yocto compilation
arevalo
arevalo Posts: 2 ✭✭
I am trying to install Teamviewer IOT to a OS for a custom board based on iMX8MN. I use the Zeus version and I have followed this steps:
  1. I downloaded "meta-teamviewer-iot-agent": https://github.com/teamviewer/meta-teamviewer-iot-agent
  2. And I followed the steps from the community article
However when I run the compilation the do_fetch fails:
HTTP request sent, awaiting response... 403 Forbidden
2022-07-13 08:04:14 ERROR 403: Forbidden.
Why do I have this issue? How could I solve it?
Many thanks
Best regards, Sonia.
Best Answers
  • mircea_c
    Answer ✓
    Hello @arevalo
    Could you please try again now and let us know if the issue is still exist as it was an issue with url?
    Best Regards,
    Mircea
    Tech Support IoT
  • davitivanyan
    davitivanyan Posts: 4 Staff member 🤠
    Answer ✓
    HI @arevalo
    As you can see from the article it was for Raspberry Pi 3, which has ARM CPU Architecture.
    You can basically change the branch for your device with aarch64(ARM64) CPU architecture. (I've just created for you).
    git clone --branch=zeus_aarch64 https://github.com/teamviewer/meta-teamviewer-iot-agent
    Best Regards,
    Davit Ivanyan
    Release Engineer of IoT
  • mircea_c
    Answer ✓
    Hello @arevalo
    Best Regards,
    Mircea
    Tech Support IoT
  • arevalo
    arevalo Posts: 2 ✭✭
    Hi @mircea_c,
    The do_fetch worked fine, and this issue was solved to me. Many thanks for it.
    However, after install the fixed meta-teamviewer-iot-agent I got an other problem due to the architecture:
    ERROR: teamviewer-iot-agent-1.0-r0 do_package_qa: QA Issue: Architecture did not match (ARM, expected AArch64) on /work/aarch64-poky-linux/teamviewer-iot-agent/1.0-r0/packages-split/teamviewer-iot-agent/usr/libexec/teamviewer-iot-agent/TVResource_zhCN.so
    Architecture did not match (ARM, expected AArch64) on /work/aarch64-poky-linux/teamviewer-iot-agent/1.0-r0/packages-split/teamviewer-iot-agent/usr/libexec/teamviewer-iot-agent/CertificateManagerHelper
    Architecture did not match (ARM, expected AArch64) on /work/aarch64-poky-linux/teamviewer-iot-agent/1.0-r0/packages-split/teamviewer-iot-agent/usr/libexec/teamviewer-iot-agent/teamviewer-iot-agent-config
    Architecture did not match (ARM, expected AArch64) on /work/aarch64-poky-linux/teamviewer-iot-agent/1.0-r0/packages-split/teamviewer-iot-agent/usr/libexec/teamviewer-iot-agent/TVResource.so
    Architecture did not match (ARM, expected AArch64) on /work/aarch64-poky-linux/teamviewer-iot-agent/1.0-r0/packages-split/teamviewer-iot-agent/usr/libexec/teamviewer-iot-agent/mosquitto
    Architecture did not match (ARM, expected AArch64) on /work/aarch64-poky-linux/teamviewer-iot-agent/1.0-r0/packages-split/teamviewer-iot-agent/usr/libexec/teamviewer-iot-agent/teamviewer-iot-mon-agent [arch]
    Could I solve this issue or do I have any alternative to add teamviewer-iot to my OS?
  • davitivanyan
    Answer ✓
    HI @arevalo
    Best Regards,
    Davit Ivanyan
