fun stuff . anything higher then 15.2 crashes
Faulting application name: TeamViewer.exe, version: 15.7.7.0, time stamp: 0x5efdfc6b
Faulting module name: TeamViewer.exe, version: 15.7.7.0, time stamp: 0x5efdfc6b
Exception code: 0xc0000409
Fault offset: 0x0235d65e
Faulting process id: 0x9b0
Faulting application start time: 0x01d657794c5af78a
Faulting application path: C:\Program Files (x86)\TeamViewer\TeamViewer.exe
Faulting module path: C:\Program Files (x86)\TeamViewer\TeamViewer.exe
Report Id: 0eb10ab7-c390-11ea-86f9-b8ee65ffdb66
Faulting package full name:
Faulting package-relative application ID:
    Hello @mememe1312,
    I'd recommend you to follow these installation troubleshooting instructions:
    I hope this could help. ?
    Best regards
  • mememe1312
    mememe1312 Posts: 4 ✭✭
    install is not a problem.
    it runs for a while then crashes then restarts
  • mememe1312
    Faulting module name: KERNELBASE.dll, version: 6.3.9600.19724, time stamp: 0x5ec50c3e
    Exception code: 0xe06d7363
    Fault offset: 0x000156e8
    Faulting process id: 0x1bc4
    Faulting application start time: 0x01d65d13b937b156
    Faulting module path: C:\WINDOWS\SYSTEM32\KERNELBASE.dll
    Report Id: daff1617-c910-11ea-8702-b8ee65ffdb66
  • BricePradel
    BricePradel Posts: 1
    Dear community,
    I'd like to report the same issue that is propagating over all computers we do have and all our users.
    Here is what I do have on my laptop (with my account, tensor license) for example :
    Faulting application name: TeamViewer.exe, version: 15.31.5.0, time stamp: 0x62b45bcc
    Faulting module name: KERNELBASE.dll, version: 10.0.22000.527, time stamp: 0xc2abc35e
    Fault offset: 0x0013ece2
    Faulting process ID: 0x2204
    Faulting application start time: 0x01d89cda5635ec06
    Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
    Report ID: 7a96a437-d5ca-43cf-b218-5756a28d8ef4
    We need this to be urgently fixed as it becomes a major issue if our remote tool is not stable for homeworking purpose.
    Thanks.
  • MYITWORKS
    MYITWORKS Posts: 1
    Same problem here.
    Version 15.36.9 (32-bit)
    Name der fehlerhaften Anwendung: TeamViewer.exe, Version: 15.36.9.0, Zeitstempel: 0x637f94b4
    Name des fehlerhaften Moduls: KERNELBASE.dll, Version: 10.0.19041.2311, Zeitstempel: 0xa27d2a44
    Ausnahmecode: 0xc000041d
    Fehleroffset: 0x0012e092
    ID des fehlerhaften Prozesses: 0x893c
    Startzeit der fehlerhaften Anwendung: 0x01d90a29a4ec4c36
    Pfad der fehlerhaften Anwendung: C:\Program Files (x86)\TeamViewer\TeamViewer.exe
    Pfad des fehlerhaften Moduls: C:\WINDOWS\System32\KERNELBASE.dll
    Berichtskennung: 6b42aadd-cfc7-4e59-90e7-b76ecbc73cd2
    Vollständiger Name des fehlerhaften Pakets:
    Anwendungs-ID, die relativ zum fehlerhaften Paket ist:
  • SoulDee
    SoulDee Posts: 1 Newbie
    Same Problem here.
    Version 14.3.4730.0
    Name der fehlerhaften Anwendung: TeamViewer_Service.exe, Version: 14.3.4730.0, Zeitstempel: 0x5cf7bfff
    Name des fehlerhaften Moduls: KERNELBASE.dll, Version: 10.0.19041.3930, Zeitstempel: 0x640b6fb9
    Ausnahmecode: 0xe06d7363
    Fehleroffset: 0x0013fa72
    ID des fehlerhaften Prozesses: 0x34f8
    Startzeit der fehlerhaften Anwendung: 0x01da541b6aff395c
    Pfad der fehlerhaften Anwendung: C:\Program Files (x86)\TeamViewer\TeamViewer_Service.exe
    Berichtskennung: 803b7316-f3cd-480c-aad3-aa7abe963cb9
    Are there any Fixes, suggestions which can fix the Problem ?
