Anyone getting a freeze after the "Connecting..." message in version 15.31.5
TV has been working just fine until recently. Now when I attempt to connect to one of the computers on my LAN I get the "Connecting..." message then nothing.
The last update was to 15.31.5 on July 5 and if I remember correctly it was working after that.
I'm running Linux Mint 19.1 with the 4.15.0-189-generic kernel.
Thanks,
Terry McCann
Same issue here. OpenSuse Tumbleweed, since yesterday when I updated.
Is there a way to debug the problem? I can see the following message sequence:
Client: Ready to connect (secure connection)
Server: Ready to connect (secure connection)
Client: "connecting to Partner." on the client side and the message "
Server: "Incoming connection..."
Client: "connecting...." on the client side and the message "
The message "Authenticating..." never appears on the client.
Did test under Tumbleweed, last working version of Tumbleweed is 20220826 and 20220827 is already broken. Symptoms are same, connect ends with "Connecting...". Downgrade back, close Teamviewer and "systemctl restart teamviewerd.service" helps, or reboot
sudo tumbleweed switch --install 20220827
glibc is the biggest suspect here
The following 26 packages are going to be upgraded:
apparmor-abstractions apparmor-docs apparmor-parser apparmor-parser-lang apparmor-profiles gdk-pixbuf-loader-libheif glibc glibc-32bit glibc-devel glibc-extra glibc-locale glibc-locale-base libapparmor1 libcbor0_9 libheif1
libnfsidmap1 libopencv406 libopencv_imgcodecs406 libvmtools0 nfs-client nscd openSUSE-release openSUSE-release-appliance-custom open-vm-tools open-vm-tools-desktop osinfo-db
The following product is going to be upgraded:
openSUSE Tumbleweed 20220826-0 -> 20220827-0
26 packages to upgrade.
Overall download size: 37.4 MiB. Already cached: 0 B. After the operation, 425.9 KiB will be freed.
S | Repository | Name | Current Version | Available Version | Arch
v | Main Repository (OSS) (20220827) | apparmor-abstractions | 3.0.6-2.1 | 3.0.6-3.1 | noarch
v | Main Repository (OSS) (20220827) | apparmor-docs | 3.0.6-2.1 | 3.0.6-3.1 | noarch
v | Main Repository (OSS) (20220827) | apparmor-parser | 3.0.6-2.1 | 3.0.6-3.1 | x86_64
v | Main Repository (OSS) (20220827) | apparmor-parser-lang | 3.0.6-2.1 | 3.0.6-3.1 | noarch
v | Main Repository (OSS) (20220827) | apparmor-profiles | 3.0.6-2.1 | 3.0.6-3.1 | noarch
v | Main Repository (OSS) (20220827) | gdk-pixbuf-loader-libheif | 1.12.0-3.1 | 1.12.0-4.1 | x86_64
v | Main Repository (OSS) (20220827) | glibc | 2.35-6.1 | 2.36-1.1 | x86_64
v | Main Repository (OSS) (20220827) | glibc-32bit | 2.35-6.1 | 2.36-1.1 | x86_64
v | Main Repository (OSS) (20220827) | glibc-devel | 2.35-6.1 | 2.36-1.1 | x86_64
v | Main Repository (OSS) (20220827) | glibc-extra | 2.35-6.1 | 2.36-1.1 | x86_64
v | Main Repository (OSS) (20220827) | glibc-locale | 2.35-6.1 | 2.36-1.1 | x86_64
v | Main Repository (OSS) (20220827) | glibc-locale-base | 2.35-6.1 | 2.36-1.1 | x86_64
v | Main Repository (OSS) (20220827) | libapparmor1 | 3.0.6-2.1 | 3.0.6-3.1 | x86_64
v | Main Repository (OSS) (20220827) | libcbor0_9 | 0.9.0-1.4 | 0.9.0-2.1 | x86_64
v | Main Repository (OSS) (20220827) | libheif1 | 1.12.0-3.1 | 1.12.0-4.1 | x86_64
v | Main Repository (OSS) (20220827) | libnfsidmap1 | 1.0-34.1 | 1.0-35.1 | x86_64
v | Main Repository (OSS) (20220827) | libopencv406 | 4.6.0-1.1 | 4.6.0-2.1 | x86_64
v | Main Repository (OSS) (20220827) | libopencv_imgcodecs406 | 4.6.0-1.1 | 4.6.0-2.1 | x86_64
v | Main Repository (OSS) (20220827) | libvmtools0 | 12.0.0-1.3 | 12.1.0-1.1 | x86_64
v | Main Repository (OSS) (20220827) | nfs-client | 2.6.2-34.1 | 2.6.2-35.1 | x86_64
v | Main Repository (OSS) (20220827) | nscd | 2.35-6.1 | 2.36-1.1 | x86_64
v | Main Repository (OSS) (20220827) | open-vm-tools | 12.0.0-1.3 | 12.1.0-1.1 | x86_64
v | Main Repository (OSS) (20220827) | open-vm-tools-desktop | 12.0.0-1.3 | 12.1.0-1.1 | x86_64
v | Main Repository (OSS) (20220827) | openSUSE-release | 20220826-1790.1 | 20220827-1792.1 | x86_64
v | Main Repository (OSS) (20220827) | openSUSE-release-appliance-custom | 20220826-1790.1 | 20220827-1792.1 | x86_64
v | Main Repository (OSS) (20220827) | osinfo-db | 20220727-1.1 | 20220727-2.1 | noarch
