Devices API endpoint question
I want to use the Teamviewer API to automatically remove our machines from Teamviewer, i can see there is the devices endpoint /api/v1/devices with the parameter option for "name" that will return the device ID
However when I use that endpoint with a device name (https://webapi.teamviewer.com/api/v1/devices?parameters.name=DV00310) it just returns a full list of every machine in our organisation. I can see on the returned json that "name" isn't actually an option it returns, am I using this wrong?
"devices": [
"remotecontrol_id": "string",
"device_id": "string",
"userid": "string",
"alias": "string",
"groupid": "string",
"description": "string",
"online_state": 0,
"policy_id": "string",
"assigned_to": true,
"supported_features": "string",
"last_seen": "2022-10-18T10:07:33.519Z",
"teamviewer_id": "string"
Can someone point me in the right direction? My aim is to create a script that allows us to delete a device based on its hostname, I know you need the device ID to call the endpoint which is why I'm wanting to filter out the info based on the device name
Thank you,
Andrew
did just this a couple of days ago, since there's no way to fetch a single device you need to get all devices and the filter out the right computer via Alias. After that use the DELETE /api/v1/devices/{id}
@SuperD0S Thats what i was hoping to avoid, had a similar attempt go wrong a few years ago, do you have a sample script I could reference by any chance? I'll be writing this in Powershell but any language would be good to see
Forgot to say you can query a single device but you need to use the Teamviewer ID but often you want to query via the alias field which often is the computer name.
Here's a script that utilize a script token that you can create in TeamViewer Mangement Console (https://login.teamviewer.com/nav/profile/apps):
#Remove Teamviewer Device
#Vars
$tvApiVersion = 'v1'
$tvApiBaseUrl = 'https://webapi.teamviewer.com'
$accessToken = 'ENTER YOUR SCRIPT TOKEN'
$DeviceApi = "$tvApiBaseUrl/api/$tvApiVersion/devices"
function Get-TeamViewerDevices {
param (
[Parameter(Mandatory = $true)][string]$accessToken,
[Parameter(Mandatory = $false)][string]$deviceID,
[Parameter(Mandatory = $false)][string]$alias
try {
if ($deviceid -and !$alias) {
$(Invoke-RestMethod -Uri "$DeviceApi/$deviceid" -Method Get -Headers @{authorization = "Bearer $accessToken" } -ErrorAction Stop).devices
elseif ($alias -and !$deviceid) {
$(Invoke-RestMethod -Uri $DeviceApi -Method Get -Headers @{authorization = "Bearer $accessToken" } -ErrorAction Stop).devices | Where-Object -FilterScript { $_.alias -match $alias }
elseif (!$alias -and $deviceid) {
else {
"Please Use only deviceID OR alias!"
catch {
Write-Error $PSItem.Exception.Message
function Remove-TeamViewerDevice {
[CmdletBinding(SupportsShouldProcess)]
param (
[Parameter(Mandatory = $true)][string]$deviceid
try {
if ($PSCmdlet.ShouldProcess($deviceid)) {
Write-Host "Deleting TeamViwer device: $deviceid" -ForegroundColor Green
$(Invoke-RestMethod -Uri "$DeviceApi/$deviceid" -Method Delete -Headers @{authorization = "Bearer $accessToken" } -ErrorAction stop )
else {
Write-Host "WhatIf: The TeamViewer device with ID $deviceid will be deleted!" -ForegroundColor Yellow
catch {
#Example: Remove Computer with Alias "TestComputer"
$device=(get-teamViewerDevices -accessToken $accessToken -alias "TestComputer").device_id
Remove-TeamViewerDevice -accessToken $accessToken -deviceid $device
@AndrewTaylor did you get it to work?
