Password not generated
How do I get a password in the allow remote control panel?  My ID number is displayed but no password to allow a friiend to see my screen.
Also why do I have an alert that says   DESKTOP-FUHCDB1   Free disk space is below 10%
There is many Gbs of space available
  • Chiron
    Chiron Posts: 229 ✭✭
    For your password:
    • Options > Security Tab > Password strength - Make sure it isn't set to Disabled
    • You can also set a personal password that will not change.
    For the hard drive alert:
    You may be reading a USB drive or partition that has less space available than your C:\ drive. If you just want the alert to go away, you can disable health checks.
    Options > Advanced > uncheck Enable integrated system health checks
