can't deactivate mouse pointer
I use Teamviewer v12.83369 on many windows 10 devices.
but only on one pc I have the prob, that the mouse pointer appears twice, in the options it's deactivate like on all other win10 devices (there is no problem with mouse pointer).
I do not use any special software or hardware configurations.
I tried to uninstall teamviewer and cleaned files and registry and installed Teamviewer 12 Host new. with a new teamviewer number! the problem still exists and the mouse pointer appears twice!!
what can I do to solve the problem?
  • I have the same problem. That option is turned off, but it still shows the remote cursor. Never had this problem on Windows 7.
    Another thread said something about it depending on the laptop screen being closed or not, but I'm on a desktop, so I experimented with the monitor off or not.
    => It only happens if the remote monitor is off. The moment I turn the monitor back on the extra cursor disappears.
  • berkcan
    berkcan Posts: 1
    hi, that box if off in my tw but i still see mouse pointer. i connected my phone with a mouse and a keyboard but i cant play games bcs of this problem. My pc is windonws 10 pro.
  • SysC0mp
    SysC0mp Posts: 2 ✭✭
    I get the same problem, no possibility to hide the remote cursor on some machines. I validated that every option is set correctly in TeamViewer.
  • klepp0906
    klepp0906 Posts: 16 ✭✭
    any developments on this?  Same issue, only between two of my pcs.  In one direction at that.
    all pc's have show remote cursor disabled.   From A to B, A shows cursor.   From B to A, B does not.
    From A to C, no cursor.
    Ironically the desktop to laptop = no remote cursor showing.  desktop to desktop (in one particular direction) = remote cursor showing.
    argh.
  • P_Carlyle
    P_Carlyle Posts: 1
    01/17/2022:
    I'm having the same problem... Is there a fix yet???
  • AlenaC
    AlenaC Posts: 918 Moderator
    Hi @P_Carlyle
    thanks for your post. Welcome to our community :)
    Could you please check that you have our latest version downloaded on both devices and the option "show remote cursor" is not checked in the client options --> tab remote control?
    Thanks in advance for your answer
    Best, Alena
