Suppression of unattended password prompt on first run
James_IT
James_IT Posts: 5 ✭✭
I've been working on a mass deployment setup of the new TeamViewer 12 client using the account assignment tool method. The installation itself goes well in complete silence without the user being notified which is great, however, I am unable to stop a pop up appearing on the user's screen the next time they reboot which is the "setup unattended access" screen.
Is there a specific way to ensure this prompt does not appear after installation?
  • iainwels
    iainwels Posts: 121 ✭✭
    Hello James_IT,
    Could you make a screenshot and send it in this forum *IMPORTANT* BLACK OUT ALL YOUR USER RELATED DATA THIS IS AN OPEN FORUM *IMPORTANT*
    Iain Wels,
    ICT-Support
  • James_IT
    Here is an example, the window appears but the user isnt actually able to set a password, they just have to click next/ok until it disappears. It will however cause unnecessary support calls so I need to stop it appearing.
