Authy on Android OK, Authy on Chrome Never Works
kc27
kc27 Posts: 2 ✭✭
Hi
I use Authy for two factor authentication. The android application always results in a six digit code that is accepted by TeamViewer. When I run the Authy plug-in on Chrome (Window 7, 64 bit) a six digit number is generated, but it is never accepted by TeamViewer. Is this something I can resolve, or do I need to find a different two factor authenticaion tool that will generate a working number from a PC?
  • Reyhan
    Dear kc27,
    The security code is valid for only 30 seconds. Perhaps it is due to the date/time setting on your Android device.
    Please make sure that "Automatic date and time" setting was set.
    After that, could you please restart the authenticator-app.
    I hope this is helpful!
    Reyhan
  • kc27
    kc27 Posts: 2 ✭✭
    Hi - thanks for the response. I wasn't clear in stating my problem:
    Authy app on Android always generates a valid security code
    Authy plug-in for Chrome browser on Windows desktop never generates a valid security code
    How do I resolve the problem with the Authy plug-in in the Chrome browser? The PC's time settings are accurate.
