Installation Error on Ubuntu 17.04
Hi, I'm trying to install teamviewer on ubuntu 17.04.
To do that I've downloaded teamviewer_12.0.76279_i386.deb, I launch it but when I click on install button nothing happen.
So by command line I've tried the following command:
apt install /teamviewer_12.0.76279_i386.deb
But the result was an error: unsupported file given on command line
What's wrong??
  • luca72
    luca72 Posts: 2
    Thank you ChristianCay,
    I've tried your solution successfully.
  • afsah
    afsah Posts: 2
    Dear Christian,
    I am facing the same problem but the mentioned solution didn't work. I am using Ubuntu 16.04.
    Thanks,
    Afsah
  • ChristianCay
    Dear Afsah,
    Thank you for contacting TeamViewer.
    Is it possible display the out that you're getting to solve your issue?
    We are looking forward to your comments.
    Christian
  • afsah
    afsah Posts: 2
    Dear Christian,
    Apologies for the delay. Attached is the screnshot.
    While running the first command, I got this, "Errors were encountered while processing:
     teamviewer:i386". And while running the second I got,  "Unpacking libpng12-0:i386 (1.2.54-1ubuntu1) over (1.2.50-2+deb8u3) ...
    dpkg: error processing archive /var/cache/apt/archives/libpng12-0_1.2.54-1ubuntu1_i386.deb (--unpack):
     trying to overwrite shared '/usr/share/doc/libpng12-0/KNOWNBUG', which is different from other instances of package libpng12-0:i386
    Processing triggers for libc-bin (2.23-0ubuntu9) ...
    E: Sub-process /usr/bin/dpkg returned an error code (1)"
    Afsah
  • hi - i did this installation and it works - :-( but only in one direction. If I'm at the Ubuntu Desktop I'm able to control my iMac and my Win10 computers. If I try to control the Ubuntu-Laptop the connection works and I do see my Ubuntu Desktop.
    BUT: I can move the mouse in every way :-) nothing happens on the Ubuntu Desktop...
    PLEASE: heeeeelp? - since three day I cannot fix this.... I struggle
    kind regards, Achim
