Use terminal commands in the target copmuter
Hello !
I am a beginner with teamviewer....I manage to transfert some files but I would like to control the "target computer" like mine, so I would like to use linux terminal in the "target computer", Is it possible ?
Thanks in advance for your help,
Franck
  • iainwels
    iainwels Posts: 121 ✭✭
    Hello Francky,
    I am not that fermilliar with linux, but linux terminal is kind of like CMD in windows right? You can just open it on the normal way you should open it on your own linux. Here is a screenshot!
    Afbeeldingsresultaat voor how to open linux terminal
    I hope this helps,
    Iain Wels,
    ICT-Support
  • Hi ! thanks for your reply, so you are saying that I just have to use it like "my computer" but when I open a terminal, according to it I am still on "my computer" and not in the "target one".... And I don't have the same "menu" than you .... :(
  • iainwels
    Hello Francky,
    Could you make a screenshot?
    Iain Wels,
    ICT-Support
