teamviewer disconnects
Hi. I am a particular user of the application and I use it to control my pc (with windows 7) with a fifth generation ipod. I have the modem next to the pc and when I try to control it from a distance of approximately 8 meters, teamviewer is permanently disconnected (at that distance from the modem I can use the internet on my ipod for other things which I deduce is a teamviewer problem) Greetings and thanks Rodrigo
Hello. I am a particular user of the application and I use it to control my pc (with windows 7) with a fifth generation ipod. I have the modem next to the pc and when I try to control it from a distance of approximately 8 meters, teamviewer is permanently disconnected (at that distance from the modem I can use the internet on my ipod for other things which I deduce is a teamviewer problem) Greetings and thanks Rodrigo
