Is it possible to rename from No. type ID to Text type or sth else?
SYLEE
SYLEE Posts: 1
Now I'm using multi IDs & devices.
As you know Team viewer's formal ID is based on No. type.
but it makes me confusing every time.  Each ID is very confusing to recongnize which is a proper device I want to connect.
Is it possible to rename or convert my IDs from No. type to Text type or something else easy recognizable??
  • bartlanz
    bartlanz Posts: 315 ✭✭✭
    Are you using the computers & contacts list? This allows you to apply logical names to IDs pretty easily.
    Bart Lanzillotti
