teamviewer 12 on ubuntu 17.10 unable to allow incoming remote connections. But I am able to remote.
I just got Teamveiwer 12 installed on ubuntu 17.10 and i am not able receive incoming remote connections. However, I can get remote out with no prob.
  • ChristianCay
    Dear chamilton,
    To make sure we are able to understand your issue, do you have a TeamViewer ID on this device?
    Are you able to make outgoing connections?
    Do you have Wayland Enabled?
    Let us know so we are able to find out a solution for you.
    Christian
  • FranklinNoyes
    FranklinNoyes Posts: 2 ✭✭
    I just upgraded to Ubuntu 17.10 which now uses GNOME instead of Unity as the default desktop environment. When I connect to my Ubuntu machine (from any other device regardless of OS) I just see a black screen in the remote window. I'm using Teamviewer 12, and I've already tried purging Teamviewer and reinstalling it.
    I should mention that if I log out of GNOME and into Unity it works just like before, so the problem must be related to the new desktop envirnment.
  • I had the same issue with @FranklinNoyes after I upgraded to 17.10, looks like it is a common issue, is TeamViewer team going to help us with a patch for it?
  • I did two fresh install of Ubuntu 17.10 and installed Teamviewer but when I try to connect to my Ubuntu machines from Windows or Ubuntu OS, I receive the error seen in image below. I'm using Teamviewer 12.
    This is the error I recieve:
    Regarding Your Questions:
    Answer: I recall seeing one when I was connecting to other nodes from the node.
    Answer:  Yes I am able to make outgoing connectiones.
    Answer: That is now the default display server.
  • I have the same problem with a fresh 17.10 install. However choosing Xorg session from login screen solves the problem (e.g. https://itsfoss.com/switch-xorg-wayland/)
    Nevertheless a solution for wayland would be very nice.
  •  Hello, I  have the same problem. Black screen after logon with latest teamviewer 12 on Ubuntu 17.10. I am on Xorg, not on wayland. I reinstalled the client, same.
  • I also tested switching back to Unity, no way the session stays black.
  • the same issue :(
  • Same here! :smileysad:
  • S(h)ame here...
  • Solution found.
    Just set Ubuntu on Xorg before login, and it works!
  • It's not a solution, it's a **bleep** workaround. Solution will be to support Wayland where all Linux communities are going.
  • This is not a solution, but a workaround only.
  • How to change the desktopHow to change the desktop
    To view the remote desktop I have successfully adopted the following simple procedure.
    The default desktop of Ubuntu 17.10 ,has to be changed from Ubuntu to Ubuntu on Xorg
    Start computer and make changes (select Ubuntu on Xorg) in the Ubuntu login screen as above.
    Then enter the password of the computer and start
    Then  the problem will be  solved
  • As @Trudide12 and @maggiv8 posted, this is a workaround, not a solution!
  • This is the solution I was looking for in Fedora 25. Now I understand it all.
    Thank you very much!!!
