allowing remote control where is the pw ?
I want to get a support
if I open teamviewer 13 beta , in Allow Remote Control I get an ID but there is no password
how can I get the password ?
thanks
Hi again,
can you change the part I´ve marked in yellow to secure (6 characters)?
You can remove the black dots under Mot de passe if you don´t want to have a personal password.
I hope that helps you, Esther
Community Manager5
Hi @erickb
It looks like your randon password is disabled.
You can enable the random password for spontaneous access in the TeamViewer options --> Security --> Password strength --> choose at least Secure (6 characters)
Otherwise you can connect via the personal password, which has been set for your device.
All the best, Esther
Community Manager1 -
my screen is not at all the same than yours , I cannot choose a random password, there is already a password ***** but no idea what it is
i'd like to remove that hidden password and get a random password each time
thanks0 -
Hi again,
Community Manager5 -
now it works :smileyhappy:
many thanks !1 -
I CANT EVEN OPEN THE OPTIONS PAGE WHEN I TRY I GET "the options dialog is protected with a password. Please enter the password to access the options dialog." but i dont know the password bc its not shown on my screen. ive tried my personal logon password for teamveiwer but that doesnt work either.
