teamviewer My Google Authenticator codes aren’t working ios
Hi, after switching to a new iPhone and wiping the older phone the google authenticatior codes aren't working any more. Can you plase give me instructions on how to correct this problem? Thanks
  • Iain_wels
    Iain_wels Posts: 54 ✭✭
    Hello d_dimov16,
    Let me get this clear. Did you lose you're second authorisation?
    Thank you for using teamviewer!
    Iain Wels,
    ICT-Support
  • d_dimov16
    My first authorisation was my user name and password and my second authorisation was my Google Authenticator app, but after switching to the new phone and downloading Google Authenticator and registering it throught Google 2 Step Verification process now the Google Authenticator app is running ang giving me codes that when I enter them on TeamViewer account it says that the code is incorect
  • Iain_wels
    Hello d_dimov16,
    Thats awfull! But i am sorry i don't think i can help you any here...
    Iain Wels,
    ICT-Support
  • Reyhan
    Dear @d_dimov16
    I send you a private message with further information.
     @Iain_wels Thank you for your help. :smileyhappy:
    Best regards.
    Reyhan
    Reyhan
  • Reyhan
    Dear @d_dimov16
    Best regards.
    Reyhan
    Reyhan
