Team Viewer 13Beta MSI instead of 12
Where do I get the TeamViewer12 MSI? When using the link on the website or shown in the youtube-video it downloads 13Beta-MSI.
  • JedenTag
    JedenTag Posts: 38 ✭✭
    @atsa is correct. The link for Windows v12 download gets a zip file, the manuals are for v12, but the MSI files are version 13. There is no indication that this is version 13 until you are running the installer.
     TEAMVIEWER, this is a dirty trick. The links for v13 are clear. The links for v12 are wrong.
    I hope this was a mistake.
  • Chiron
    Chiron Posts: 229 ✭✭
    I checked the Previous Versions Page, but I didn't see anything for version 12. Only 10 and 11.
    https://www.teamviewer.com/en/download/previous-versions/
  • Chiron
    I just tried https://www.teamviewer.com/en/download/windows/msi/ and provided my license number, but it didn't work.
    "The license is not of the right type."
    I have done this before (with this license) and everything worked. I thought 12 was still the current version since 13 is in beta testing.
  • Julia
    I checked and for me it was possible to download the MSI for version 12.
    Go to: https://www.teamviewer.com/en/download/windows/
    Scroll down until you see "TeamViewer MSI package" - if you click on the blue button "Download MSI" you receive the MSI package for version 12
    Julia
  • atsa
    atsa Posts: 5
    Yay, but when you extract the zip a version 13 msi will show up.
  • Julia
    Hi @atsa,
    I ran the MSI wrapper and got the installation for TeamViewer 12 - do you want to install the Host module or the full version?
    Julia
  • atsa
    atsa Posts: 5
    I get this MSI.
  • atsa
    atsa Posts: 5
    I need the full install.
  • atsa
    atsa Posts: 5
    Downloaded the 12-MSI now by using the license key and not being logged in. Thanks for the hint, Julia
    @Julia wrote:
    Thank you so much for your help - we found the problem. If you download the package with the license number, you receive version 12. However, if you sign in with your TeamViewer account, it will download the package for version 13.
    I will clarify this internally and keep you updated
