QuickSupport don't work anymore
We use for our servicedesk, QuickSupport with a downloadlink.
But when we use it now, after implement TV 12 it don't work anymore.
When a n user type the link in their browser,  they get a rederict to Teamviewer 12 start site.
So they don't get the sessiecode anymore.
Can somebody help us? thanks, Andre
  • Julia
    Hi awessels,
    Thank you for the post.
    Does the problem occur on Mac systems? If yes, we are aware of the behavior and are working on a solution.
    I will reply to this post as soon as this is fixed.
    Short update: The problem occurs on Linux and Mac systems
    Julia
  • awessels
    awessels Posts: 6 ✭✭
    Thanks Julia, that's the case.
    Regards, Andre
  • Julia
    Hi :)
    Thank you for your patience.
    We fixed the describted problem - however it is not possbile to start the downloaded module at the moment. We are already working on this.
    I will keep you updated.
    Julia
  • awessels
    Hi Julia,
    I tried our QuickSupport link on Windows, and thats no problem. (WIN8.1)
    On El Capitan on a Mac it won't work now, because the mac says that the downloaded file is corrupt. I only can remove it to the recycle bin.
    greetz, Andre
  • catnamedmac
    catnamedmac Posts: 3 ✭✭
    I'm also experiencing the same issue on the Mac. I am running macOS Sierra.
  • catnamedmac
    Can we get an update on this issue? It's difficult to provide service to our clients without this functionality issue being resolved for the Mac.
    Jim Monkiewicz
  • awessels
    Thank You! it's working now!
    greetz, Andre
  • comtech2011
    im on LINUX same problem not working
  • aoganesian
    For some reason, downloaded Quicksupport executables don't start automaticaly anymore after downloading on Windows 10, which leads to a lot of confusion with our users because ofthen they don't know what to do
