TeamViewer mobile apps menu
Areckee
Areckee Posts: 2 ✭✭
Hello, I am using TeamViewer for quite a few years. I have multiple laptops which I access from each other as well from my iPhone and Android smartphone. Every time I want to use the top menu (Esc, Tab, Shift, Ctrl and so on), I need to enable the whole keyboard. Is it possible to configure TeamViewer so it first shows only the top menu and - after that - the keyboard? Or maybe (as a feature request) add another button to open only top menu?
Best regards
  • Areckee
    Areckee Posts: 2 ✭✭
    Hi Jonathan,
    I thought so... But I'm glad that you will submit this as a feature request.
    I wish all of you a happy New Year.
    Areckee
