The taskbar is lost on remote pc running Win 7 after ending TeamView session.
LolaGets
Lost the taskbar on the remote PC running Win 7 & TV ver 13. Not Hidden, Not Moved, not minimized or shrunk to one line. The only way I have found to restore it has been to Log off or a PC Restart.
Please Any Suggestions? I'll be happy with a keyboard shortcut if someone knows one.
Perhaps this is a bug in TV, or Running older due to running old OS ..?
I downgraded to TV12 to overcome my taskbar problem:
Hi @LolaGets
Please have a look at my comment here:
Julia
The taskbar issue was annoying so I went back to 12. But also, for me version 13 was not performant. The graphics rendering was just poor and couldn't keep up. This all went away when I went back to 12
13.0.6447 seems to have solved all my problems I mentioned above
1
