Wont install
truevoice
truevoice Posts: 2
Hi I am trying to install teamviewer on my raspberry pi dietpi and the instructions seem to be for advanced users because i cant seem to get it right can anyone help me please we would like to purchase if we can get it to work.
  • truevoice
    Has anyone managed to get teamviewer to work on dietpi please need help
  • Victoria
    Victoria Posts: 7 Staff member 🤠
    Hi @truevoice,
    Please give more details whether you mean TeamViewer IoT or TeamViewer product?
    Victoria
  • leewilmus
    leewilmus Posts: 1
    edited March 2023
    Hi I have used this instruction to install on my raspberry pi/dietpi https://community.teamviewer.com/English/kb/articles/109831-access-the-edge-device-via-remote-appcontrol
    And everything seems to work but when I connect it authenticates then nothing happens can you help me please we really want to get this working so that teamviewer can be our choicen supplier. At the moment we using [removed per Community Guidelines] but we want to move
  • PatrickG
    PatrickG Posts: 40 [Former Staff]
    edited March 2023
    Hi @leewilmus
    Thank you for your enquiry.
    Can you clarify, what happens after the authentication process? If you see a blank window, this means, that your webserver is not configured properly.
    Please see the following manual for more details:
    https://community.teamviewer.com/English/kb/articles/109832-new-browser-engine-support-for-iot-devices
    TeamViewer IoT connects you to a web interface running on the remote device to control a machine connected to your device.
    If you want to have full remote control (desktop access) of the dietpi, please install TeamViewer Host from
    https://www.teamviewer.com/de/download/linux/
    Please do let us know if you have any further questions and we will be happy to assist you.
  • Nooby1234
    Nooby1234 Posts: 1
    I’m having a similar problem.... ( I’m a novice) that the TeamViewer iot deb file that I installed seemed to work but didn’t ask me for the TeamViewer permission part? I have the desktop icon installed but when I double click it loads with the command box and then dissapears with no TeamViewer codes?
    I’ve tried uninstalling and reinstalling abd using code I found to do an update. Tried the Linux 32/64 but deb files that both appear with a box saying ‘package cannot be found to perform this task’ any ideas ?
