How to change default for remote control.
Hi :smileyhappy:
Is it possible to change the Default Remote Control from "using password" to "Prompt for confirmation"?
Cheers, Björgvin
Björgvin Arnarsson
  • Chiron
    Chiron Posts: 229 ✭✭
    Extras > Options > Advanced > Advanced settings for connections to this computer.
    The default is Full Access. Change to Confirm All. I think the incoming connection will still need a password too.
  • Bjorgvin
    Bjorgvin Posts: 11 ✭✭
    Hi and thank's for your reply :smileyhappy: It's not the answer I'm looking for though :cathappy:
    What I mean is: I want to click on the Computer I'm going to take over and the user gets a window on his side to accept me. Today, if I click on the computer it ask's for a password. The first one is MUCH faster and the user doesn't need to find Teamviewer on his side.
    So I want the default to be "prompt for confirmation" and not "using password".
    Cheers, Björgvin
    Björgvin Arnarsson
