Ubuntu 16.04 Server - Teamviewer 12 crashes from time to time
flies
flies Posts: 6 ✭✭
the problem is teamviewer 12 started crashing recently (almost everyday). It happens after some time. Never had this issue with teamviewer11. VNC (other software) is still responsive at this time.
Here are the logs:
2017/01/08 01:55:01.485  9829 4055886656 NX1   SysSessionInfoManager: assigned session 99 to info provider 'None'
2017/01/08 01:55:01.693 9829 4074453824 NX1 XSocket observer: removing XSession: 99
2017/01/08 01:56:01.713 9829 4074453824 NX1 XSocket observer: adding XSession: 99
2017/01/08 01:56:01.715 9829 4055886656 NX1 XSession[99]: Retrieved XAuth from commandline
2017/01/08 01:56:01.744 9829 4055886656 NX1! VTSessionInfoProvider: Failed setting TTY for session 99 on display ':99'
2017/01/08 01:56:01.744 9829 4055886656 NX1 SysSessionInfoManager: assigned session 99 to info provider 'None'
2017/01/08 01:56:01.963 9829 4074453824 NX1 XSocket observer: removing XSession: 99
2017/01/08 01:57:01.983 9829 4074453824 NX1!! XSocket observer: stat failed /tmp/.X11-unix/X99, Errorcode=2
2017/01/08 01:57:01.984 9829 4074453824 NX1 XSocket observer: removing XSession: 99
2017/01/08 01:58:02.004 9829 4074453824 NX1 XSocket observer: adding XSession: 99
2017/01/08 01:58:02.006 9829 4055886656 NX1 XSession[99]: Retrieved XAuth from commandline
2017/01/08 01:58:02.036 9829 4055886656 NX1! VTSessionInfoProvider: Failed setting TTY for session 99 on display ':99'
2017/01/08 01:58:02.036 9829 4055886656 NX1 SysSessionInfoManager: assigned session 99 to info provider 'None'
2017/01/08 01:58:02.254 9829 4074453824 NX1 XSocket observer: removing XSession: 99
2017/01/08 01:59:01.274 9829 4074453824 NX1!! XSocket observer: stat failed /tmp/.X11-unix/X99, Errorcode=2
2017/01/08 01:59:01.274 9829 4074453824 NX1 XSocket observer: removing XSession: 99
2017/01/08 02:00:01.294 9829 4074453824 NX1 XSocket observer: adding XSession: 99
2017/01/08 02:00:01.296 9829 4055886656 NX1 XSession[99]: Retrieved XAuth from commandline
2017/01/08 02:00:01.327 9829 4055886656 NX1!! XClient fatal XIOError - X server connection lost, Errorcode=11
2017/01/08 02:00:01.427 39 20 GX1 CTcpProcessConnector::HandleRead(): Socket gracefully closed (PID=9829)
2017/01/08 02:00:01.427 39 20 GX1 CTcpProcessConnector::CloseConnection(): PID=9829
2017/01/08 02:00:01.427 39 20 GX1! InterProcessBase::EventFunctionInternal(): IPC-Connection Closed
2017/01/08 02:00:01.427 39 20 GX1 CTcpProcessConnector::CloseConnection(): Shutdown socket returned error 10058: Unknown error
2017/01/08 02:00:01.428 39 20 GX1!! CTcpProcessConnector::CloseConnection(): Shutdown socket returned error 10009: Unknown error, Errorcode=317
$ ./teamviewer
Init...
CheckCPU: SSE2 support: yes
XRandRWait: No value set. Using default.
XRandRWait: Started by user.
Checking setup...
Launching TeamViewer ...
Starting network process (no daemon)
Network process started (18848)
Launching TeamViewer GUI ...
terminate called without an active exception
fixme:nls:GetGeoInfoW -1 4 0x1bedd74 3 0
QMetaObject::invokeMethod: No such method QSystemTrayIcon::isVisible()
fixme:nls:GetGeoInfoW -1 4 0x1cee2ec 3 0
fixme:nls:GetGeoInfoW -1 4 0x1dee2ec 3 0
fixme:nls:GetGeoInfoW -1 8 (nil) 0 0
TeamViewer: Fatal IO error: client killed
fixme:console:CONSOLE_DefaultHandler Terminating process 27 on event 0
Is it something that you are familiar with? How can I help you more to troubleshoot the issue?
flies
  • ChristianCay
    Dear flies,
    Did you upgrade your TeamViewer 11 to 12 or it was a new installation?
    If so, please run these commands to delete any TeamViewer trace, update your system and re-install the software.
    cd /
    sudo rm -rf /home/*/.local/share/teamviewer* /home/*/.config/teamviewer /opt/teamviewer
    cd ~
    sudo apt-get update
    sudo apt-get upgrade
    wget download.teamviewer.com/download/teamviewer_i386.deb
    dpkg -i teamviewer_i386.deb
    sudo apt-get install -f -y
    Hope that solution works for you.
    Christian
  • flies
    flies Posts: 6 ✭✭
    Hi Christian,
    thank you for your reply, appreciate it.
    Unfortunately - it doesn't apply to my case since I am using standalone version tar.xz inside screen session. There are no leftovers - I have used cleanly unpacked files.
    It works fine for a few hours and then stops at some time.
  • ChristianCay
    Hi flies,
    Make sure you have the latest build of tar.xz
    You may check that running the command:
    ./teamviewer info
    Don't forget to run it from the extracted directory.
    At the moment this reply was created latest version is v12.0.71510
    You may also check the latest build from our website
    http://www.teamviewer.com/download/linux
    Christian
  • flies
    flies Posts: 6 ✭✭
    Hi Christian,
    yes it's the newest one:
    flies@xxx:~/teamviewer$ ./teamviewer info
    TeamViewer 12.0.71510 (TAR_NI)
  • flies
    flies Posts: 6 ✭✭
    Newest crash gave other error:
    Init...
    Checking setup...
    Network process started (5810)
    Invalid MIT-MAGIC-COOKIE-1 keyterminate called without an active exception
  • ChristianCay
    Hi flies,
    If you have the latest version, please make sure that all dependencies are satisfied using the following command
    sudo ./tv-setup checklibs
    The application will give you an example on how to install the missing dependencies.
    Christian
  • flies
    flies Posts: 6 ✭✭
    Hello again Christian,
    everything is intact.
    Is there any debug mode I can use to pinpoint the issue or at least allow you to make troubleshooting easier for you?
    flies@xxx:~/teamviewer$ sudo ./tv-setup checklibs
    -=- TeamViewer tar.gz check -=-
    In order to use the tar.gz version of TeamViewer,
    you have to make sure that the necessary libraries are installed.
    NOTE: Most needed libraries are 32 bit libraries, even if you are on a 64 bit system!
    Writing raw output to /home/flies/teamviewer/logfiles/DependencyCheck32.log
    Writing raw output to /home/flies/teamviewer/logfiles/DependencyCheck64.log
    Analyzing dependencies (64 bit)...
    All 64 bit dependencies seem to be satisfied!
    Analyzing dependencies (32 bit)...
    All 32 bit dependencies seem to be satisfied!
  • flies
    flies Posts: 6 ✭✭
  • ChristianCay
    Dear flies,
    Please try the following command and let us know if this solution works for you.
    cd ~/.config
    # rm -rf teamviewer
    sudo teamviewer daemon restart
    Please note that # means that you may need sudo or root permissions.
    Hope this solution works for you.
    Christian
  • hassankarimg
    @flies wrote:
    Here are the logs:
    $ ./teamviewer
    Init...
    Checking setup...
    flies
