unauthorized access
mddd
Hi - I just noticed I have team viewer installed on my computer. I'm not an expert by any means but it looks like my brother in law has been accessing my computer without me knowing. I tried opening the log files to see what he has been doing but can't really understand them. Is there anyone that can help me with this? Thanks
MDDD
If you think you have unauthorized access the simplest thing to do is to uninstall teamviewer and install teamviewer quick support when you need it. Quick support is a run once agent which will not run in the background or at startup. You will need to run it manually each time.
Good luck!
Rigel1
