Teamviewer will not start on ubuntu
towt
towt Posts: 4 ✭✭
Whenever I try and start TeamViewer, I get the following:
user@user:~/.config$ teamviewer
Init...
CheckCPU: SSE2 support: yes
Checking setup...
chmod: changing permissions of '/home/user/.config/teamviewer': Operation not permitted
chmod: changing permissions of '/home/user/.local/share/teamviewer13/logfiles': Operation not permitted
Launching TeamViewer ...
Launching TeamViewer GUI ...
/opt/teamviewer/tv_bin/script/tvw_main: line 146: /home/user/.local/share/teamviewer13/logfiles/gui.log: Permission denied
Anyone know what the issue might be? I assume it's a folder permission issue.
The only way I've managed to get it to run is to do do:
sudo su
sudo teamviewer
  • towt
    towt Posts: 4 ✭✭
    Added to OP
  • towt
    towt Posts: 4 ✭✭
    Worked perfectly! Thanks. I can make windows boxes sing and dance, but I am still learning the Linux filesystem
  • Jegujeggs
    Hi i tried the same commands but however still not able to install teamviewer successfully.
    This is what  i am currently observing in my terminal
    Init...
    Checking setup...
    chmod: changing permissions of '/home/jegu/.config/teamviewer': Operation not permitted
    chmod: changing permissions of '/home/jegu/.local/share/teamviewer14/logfiles': Operation not permitted
    /opt/teamviewer/tv_bin/script/tvw_main: line 146: /home/jegu/.local/share/teamviewer14/logfiles/gui.log: Permission denied
    Can you please help?
  • lukejmorrison
    lukejmorrison Posts: 3 ✭✭
    What's OP?
  • lukejmorrison
    I get an error like this. Any ideas?
    Last login: Wed Jan 22 10:20:25 2020 from 192.xxx.x.xx
    luke@ubuntu-s1:~$ teamviewer
    Init...
    Checking setup...
    invalid x11 configuration found
    2020-01-22-10-30-37-Teamviewer-Host-Error
