Computer is online, but I can't connect
Computer is online, but I can't connect. Both using V12 free personal. Click it, says connecting and never prompts for a password. Then it goes back to the green ready to connect.
  • schiznick69
    Same for me. Something has happened to the Team Viewer app on the remote computer and will to need log in when at that site.
    Has happened twice now when change the screen resolution on computer. Team Viewer breaks. Shows as online in My Computers. When connecting see error:
    No Connection to partner! Partner did not connect to router. Error Code WaitForConnectFailed.
  • schiznick69
    Last issue not Team Viewers fault. Windows ran out of RAM and stopped working which impacted Team Viewer.
