Cannot connect until login to teamviewer website
MRE
MRE Posts: 2 ✭✭
When I try to login from my teamviewer client, nothing happens when I try to connect.  I have to login to the teamviewer website and connect from there.  Once I do that, the client login from my pc successfully connects.  Anyone else experiencing this?  Any suggestions?
Best Answers
  • seongling
    seongling Posts: 1
    My problem similar, but not solved with remove the field and type again, the signin button still grey out. Any suggestion ?
  • davelite
    my login button is greyed out and re-entering the password does not free it uup.. any ideas?
  • bbaxter51
    I had to log into the website and add my machine to the list of trusted devices again.  Once that was done, the log in button on the app worked again.
  • BubbaDc
    Same issue - desktop client don't connect even though I am on internet typing this?  Did you get answer?
