Get Single Device Detail
I know there is:
GET /api/v1/contacts (list all contacts from the computers & contacts list)
But what I can do if I want to get only one client info ?
I do not see such feature - could anybody confirm ?
mLipok , AutoIt MVP
  • DomLan
    DomLan Posts: 490 ⭐Star⭐
    There's no detail in documentation 1.4.1.
    The service is RESTful type: so it is highly likely that the functionality is not documented, but it is feasible with a simple GET directed to specific entity:
    GET /api/ v1/contacts/123456789
    I think...(can you try it?)
    Domenico Langone
    MCSD: App Builder
  • mLipok
    mLipok Posts: 781 ⭐Star⭐
    I will try it.
    btw.
    I was thinking about:
    GET /api/v1/devices (list all devices from the computers & contacts list)
    So I will try to check both features.
    mLipok , AutoIt MVP
  • DomLan
    Ok.
    Remember to use prefix for specific entity: (eg. GET /api/v1/contacts/c123456 - GET /api/v1/devices/d987654321)
    "d" for device,  "c" for contact... and so on... (ref. man 1.3 IDs)
    Bye
    Domenico Langone
    MCSD: App Builder
  • mLipok
    Some progress.
    I use my own TVID and I get this:
    400 Bad Request
    {"error":"invalid_request","error_description":"Device does not exist.","error_code":1}
    mLipok , AutoIt MVP
  • mLipok
    This works:
    https://webapi.teamviewer.com/api/v1/contacts?email=user@domain.com
    And this:
    https://webapi.teamviewer.com/api/v1/devices?remotecontrol_id=r012345678
    and this:
    https://webapi.teamviewer.com/api/v1/devices/d012345678
    I realized (after many tests) that my question was wrong inflicted, because actually I was looking for how to check the device data based on the "remotecontrol_id" and not "device_id"
    "devices": [
    "remotecontrol_id": "r0123456RI",
    "device_id": "d0123456DI",
    "alias": "mLipok",
    "groupid": "g012345GI",
    "online_state": "Online",
    "assigned_to": true,
    "supported_features": "remote_control, chat"
    The other questions is why I'm not geting this data:
    alias – The alias that the current user has given to this device.
     description – The description that the current user has entered for this device.
     policy_id (optional) – ID of the policy that is assigned to the device. Possible values are: a policy_id, inherit. Only available with a TeamViewer Subscription license.
    In return values ?
    mLipok , AutoIt MVP
