How to REALLY use Fullscreen on 27" iMac ?
GoetzPhil
I just start using TV12 on my PC and MAC. Works ok for now but what I need is a true FULLSCREEN Mode.
When I start TV12 on my iMac I get my PC in a window - when I then click on the "fullscrenn" icon all I get is that PC window centered on a black background.
Hey guys - If I want FULLSCREEN that means the PC window is full blown onto my 27" iMac Screen - not just some centered window.
So HOW do I get TV12 to give me a TRUE FULLSCREEN ?
I have this as well and it's really annoything. Is there any workaround or fix in the pipeline TV...???
Hi everyone.
Just go to View and select Scaled.
This should fix the issue.Just note that you may need to alter the remote resolution to get a perfect fit is the aspect ratio is different.
-Scotty
Senior Moderator
Did my reply answer your question? Why not accept it as a solution to help others?1 -
This worked for me. I had to go into the nvidia setup on the remote PC to put in a custom resolution of 2560 x 1440 to match my 27" iMac. Then save that and scale the host for it to work. Rather long winded having to do that every time I want to log in. I hope there is an update soon that comes up with a fast solution for this.0
