Problems with Chat
gasanta
gasanta Posts: 3 ✭✭
For two weeks, the text written in the chat is distorted, and becomes illegible when using the Backspace or Left Arrow keys to correct the writing.
  • isakow
    isakow Posts: 1
    I am having the exact problem. Is Team Viewer developers will fix this in the current version or they will fix it into the next one?
  • CITS
    CITS Posts: 2 ✭✭
    edited March 2022
    This has been an issue for Several months. Happens across different computers. I want to say it happend after installing TV13. It **bleep** because I make a lot of typos and usually backspace a lot.
    CITS
  • Julia
    Thank you for your contribution.
    We are already aware of the problem - a fix should be included in the next release. We apologize for the inconveniences.
    Cheers,
    Julia
