win to mac access copy paste not working on mac controlling from windows
gauravdhra
gauravdhra Posts: 2
what to do ?
  • Scotty
    Hi @gauravdhra
    Is it copy-paste or drag-and-drop that is not working?
    Drag and drop unfortunately does not work between Windows and OSX, but a standard copy-paste should work if you have clipboard synchronization turned on.
    Otherwise, you of course also have file transfer.
    I hope this helps,
    -Scotty
    Senior Moderator
  • gauravdhra
    Hi!! Scotty Thanks for reply  .
    I don't want to copy from my windows .
    I want to copy from Mac os and paste it into mac itself ,so we dont need clipboard here for sure .
    I think because Mac has the cmnd key instead the ctrl key like windows ,That is why it is not copying or pasting .
  • Scotty
    Hi @gauravdhra
    The clipboard is definitely used in this case.
    When you copy, it goes into the clipboard. TeamViewer then copies that to the Clipboard of the windows machine so that when you paste, it is pasted on the windows device.
    However, if you are using Keyboard shortcuts, the windows key is what you need. Think using a windows Keyboard on a Mac.
    So it is Windows Key + C for copy.
    -Scotty
    Senior Moderator
  • hennot
    hennot Posts: 3 ✭✭
    And how to paste with a keyboard on a local Windows machine and remote Mac machine? Pressing Win+V invokes Windows's clipboard manager.
