Team viewer not accepting password
This morning, I set up a session on my home PC, took a screenshot of the ID and Password. I get to work to connect to the session and it keeps saying the password is invaild. I know im typing it right as I have it in a screenshot, and there are no power settings that would set my PC at home to turn off.
Any Ideas? Tad frustrating, is there a time out set for the passwords within the sessions? Do they auto refresh?
Hi @Vikx993
Thank you for your post. Please note, that the random password will change after each remote connection or restart of TeamViewer.
It is a better to add a personal password for unattended access, please have a look at this article in our Knowledge Base.
Best regards.
Reyhan
Reyhan1 -
I set up a personal password on the computer and turn off all hibernating ,stand by and sleep mode on the computer. But after working for a week, today i have a error that says invalid password. What could happend?
3 -
I am having the same exact problem with a Windows Server 2012 host that has the last TeamViewer installed. I allows connections from the LAN with whatever passwords I use (I mean the ones I define personally or those the program randomnly generates). But when I try to connect from the Internet using the TeamViewer's ID, I keep falling in the authentication dialog because my password is not recognized. I have collected the log so you can follow along the problem.
2018/08/02 09:53:52.812 5604 6080 S0!! Encryption.RSADecrypt exception: RSA/EME-PKCS1-v1_5: invalid ciphertext
2018/08/02 09:53:52.812 5604 6080 S0!!!CEncryption::DeCryptBCommand(): decrypt CMD_BUDDY_ENCRYPTED failed!
2018/08/02 09:53:52.812 5604 6080 S0!! CProcessCommandHandlerKeepAliveClient[9558]::CmdRequestRouteBuddy() DeCryptBCommand failed!Thanks a lot for taking the time to answer. Regards from Argentina. Ariel.
Same problem here. I had been accessing remotely for exactly one week. Now I get an invalid password message.
I dont understand this. I have a windows10 machiine with a password on that I remote into. I rebooted it this morning and then tried to connect remotely using the windows password (after connecting using teamviewer). I know my passowrd is ocrrect but it wont log me on?
When I go home and log in to the machine direct it will let me on. I also tried the on screen keyboard but that didnt work.
I also cannot connect, it says the Password is invalid (After I just signed in using my Teamviewer account) and the machine that I am trying to connect to is set up for unattended access.
2 -
I have been encountering the same problem with the web connector. Then I try the exact same password on the chrome extension and it works. Seems to be a problem with the web connector.
My online account will accept my password for the account but not the app on my mac book. What is weird, is if I log into teamviewer online through a web browser and then go to connect to another device, the browswer will ask to open the app. When I click allow, the browswer will open the app and automatically submit the password and the whole app functions find until my computer times out, then I have to go through this whole procedure again to get teamviewer app to work, which is the only way for my mac to connect to a remote computer.
I just put the app on my phone and encountered the same problem.. Did you ever get an answer that works?
I appreciate your help!!
-Nick
