Quick support and SSL https
Hi
Sorry if this is in the wrong forum.
I used this codegenerator to make a buton on my webpage for quicksupport
https://www.teamviewer.com/en/company/badgegenerator.aspx
Problem is when i insert it at my page with ssl https, browsers do not accept my page 100% (grey keylock = somewath not safe /some elements not safe)
Is there a good way around this. To make a quicksupport buton that is not generatiing this warning?
edit: I have the pro/payed version if this make any difference
Hi @Teamf,
You are right. The reference snippet construction page downloads HTML portions that still refer to TeamViewer sites over HTTP.
In any case, if you browse a random address produced by the tool, you are automatically redirected to the HTTPS protocol.
I think you can intervene manually by replacing:<img src="http
/www.teamviewer.com/link/?url=979936&id=1325516601" alt="TeamViewer for Remote Support" title="TeamViewer for Remote Support" border="0" width="120" height="60" />
with:
<img src="https
Of course you can also replace the HTTPS protocol on the hyperlink (href="https://....") for the download operation (QS, QJ and Full Version)
Domenico Langone
MCSD: App Builder
Find this helpful? Say thanks by clicking on the Thumbs Up button.6
Hi @Teamf,
with:
<img src="https
Domenico Langone
MCSD: App Builder
Find this helpful? Say thanks by clicking on the Thumbs Up button.6 -
Yes! Works perfect. Thank you
2 -
Do I need a paid version of Team Viewer or can I use a free version for this?
Hi @mrbquick,
in Knowledge Base -> Customization you'll find this. It starts with this incipit:
'This article applies to users with a Business-, Premium- or Corporate license.'
Domenico Langone
MCSD: App Builder
Find this helpful? Say thanks by clicking on the Thumbs Up button.0
