Teamviewer 12 can't connect !!! Windows 10
wp78
wp78 Posts: 4 ✭✭
Dear support ! Dear users!
I have a problem with conection from two pc's on windows 10 - i see only : Not readey.check connection. I works till 2PM today. After - still have a problem with connection.
Tested on: local cable ISP - Vectra and GSM Carrier - Orange
  • mikeKey
    mikeKey Posts: 4
    I had this problem on windows 10......
    closed teamviewer
    went into task manager
    found a running teamviewer task and ended it
    started teamviewer again and it seems to work.
