[Update: 13.1.8286] Core dumps on ubuntu 16.04
On 2 ubuntu 16.04.4 LTS, Teamviewer full crash dumps :
$ teamviewer
Init...
CheckCPU: SSE2 support: yes
Checking setup...
Launching TeamViewer ...
Launching TeamViewer GUI ...
Erreur de segmentation (core dumped)
The remote screen is opening the first time then it closing and after  re opening the windows the crash dump arrive.
thanks
  • I'm having the same problem on teamviewer_13.1.3026.
    Init...
    Checking setup...
    Aborted (core dumped)
    The GUI opens up and doesnt load..then leads to crash.. Need help!
  • fresa
    fresa Posts: 3 ✭✭
    try open in terminal
  • This output was form opening in the terminal.
  • fresa
    fresa Posts: 3 ✭✭
    hm, what in logs?
  • Last 20 lines....
    ==> /var/log/teamviewer13/TeamViewer13_Logfile.log <==
    2018/10/15 00:10:47.895 7081 **Please do not post TeamViewer IDs**40960 S TVRouterClock Schedule next request in 0 seconds
    2018/10/15 00:10:47.895 7081 **Please do not post TeamViewer IDs**40960 S CSendCommandToMaster::SendBCommandToMaster: CC=3 CT=52
    2018/10/15 00:10:47.895 7081 **Please do not post TeamViewer IDs**40960 S Updated sessions: [ X0 (**Please do not post TeamViewer IDs**) CA ritwik ] [ F (**Please do not post TeamViewer IDs**) L root ]
    2018/10/15 00:10:47.895 7081 **Please do not post TeamViewer IDs**40960 S UpdateOnlineState newOnlineValue 1
    2018/10/15 00:10:47.941 7081 **Please do not post TeamViewer IDs**33664 S TVRouterClock: received router time: 20181015T041047.910506
    2018/10/15 00:10:47.941 7081 **Please do not post TeamViewer IDs**33664 S TVRouterClock Schedule next request in 43200 seconds
    2018/10/15 00:10:48.151 7081 **Please do not post TeamViewer IDs**18528 S AsyncMessaging::UnregisterAtAsyncMessageProvider(): Unregister successful
    2018/10/15 00:10:49.073 7081 **Please do not post TeamViewer IDs**33664 S CSendCommandToMaster::SendBCommandToMaster: CC=3 CT=38
    2018/10/15 00:10:49.114 7081 **Please do not post TeamViewer IDs**18528 S SecureNetworkIPCAdapter::RegisterSharedBCmdCallback(): CC: 30, RegistrationID: 81422236-f33c-4e7e-b49f-e9169291fe0a, DyngateID: **Please do not post TeamViewer IDs**, ProcessType: 2, SessionID: **Please do not post TeamViewer IDs**
    2018/10/15 00:10:49.158 7081 **Please do not post TeamViewer IDs**26368 S!! CTcpProcessConnector::HandleRead error 104 reading from process 8864: Connection reset by peer, Errorcode=104
    2018/10/15 00:10:49.158 7081 **Please do not post TeamViewer IDs**26368 S CTcpProcessConnector::CloseConnection(): PID=8864
    2018/10/15 00:10:49.158 7081 **Please do not post TeamViewer IDs**26368 S!! CInterProcessNetwork::NewInterProcessDataAvailable(): ReadFailed session=**Please do not post TeamViewer IDs** ptype=2, Errorcode=104
    2018/10/15 00:10:49.158 7081 **Please do not post TeamViewer IDs**26368 S UpdateOnlineState newOnlineValue 0
    2018/10/15 00:10:49.158 7081 **Please do not post TeamViewer IDs**26368 S CTcpProcessConnector::CloseConnection(): Shutdown socket returned error 107: Transport endpoint is not connected
    2018/10/15 00:10:49.158 7081 **Please do not post TeamViewer IDs**16224 S TeamViewer is going offline!
    2018/10/15 00:10:49.158 7081 **Please do not post TeamViewer IDs**16224 S RemoteSessionManager::ClearAllRemoteSessions(): RemoteSession Count: 1
    2018/10/15 00:10:49.206 7081 **Please do not post TeamViewer IDs**18528 S TVRouterClock Schedule next request in 0 seconds
    2018/10/15 00:10:49.206 7081 **Please do not post TeamViewer IDs**18528 S! KeepAliveSessionOutgoing::ConnectEndedHandler(): KeepAliveConnection with US-NJC-ANX-R002.teamviewer.com ended
    2018/10/15 00:10:49.587 7081 **Please do not post TeamViewer IDs**37280 S Process 8864 in session **Please do not post TeamViewer IDs** has terminated
    2018/10/15 00:10:49.587 7081 **Please do not post TeamViewer IDs**37280 S TerminalServer::ProcessTerminated_Finalize: process 8864 terminated
  • Skott
    Skott Posts: 1
    I have the very same problem with Teamviewer 14 and tried already everything: delete every trace of teamviewer, reinstall, reboot, install via terminal, install clicking twice on the .deb file. No one has a solution for that?
    Init...
    Checking setup...
