Repo Error
Today's update has a unexpected file size.
E: Failed to fetch http://linux.teamviewer.com/deb/dists/stable/main/binary-amd64/Packages.gz  File has unexpected size (2125 != 2376). Mirror sync in progress? [IP: 99.84.254.76 80]
Hashes of expected file:
- Filesize:2376 [weak]
- SHA256:287398eaf126883ddf5f29eaa7b504e91bab237f47dc2cf0c5b6c9c201fa8e19
- SHA1:**Please do not post TeamViewer IDs**04131bf1c965cdafd00daf073f7569 [weak]
- MD5Sum:a56524f0f085802c88dd2aa43887fd7e [weak]
Release file created at: Tue, 18 Dec 2018 12:41:57 +0000
E: Failed to fetch http://linux.teamviewer.com/deb/dists/stable/main/binary-i386/Packages.gz
  • DanielStm
    @Dulanic, thanks for your feedback. It's possibly just a temporary issue due to the update.
    Can you run apt update and try to install the update again, to verify?
    Linux Developer
