Unable to run TV13 without display manager, even when using tar archive
I'm not using a display manager, I run startx directly.
According to this thread, Teamviewer should be able to run without display manager if I download and use the tar archive, but unfortunately the GUI still doesn't start.
$ ./teamviewer
Init...
CheckCPU: SSE2 support: yes
Checking setup...
Launching TeamViewer ...
Starting network process (no daemon)
Network process started (7737)
Launching TeamViewer GUI ...
Logs:
2018/01/08 00:10:32.508 7737 139992786697152 N NetWatchdog: Internet is now connected
2018/01/08 00:10:32.509 7737 139992786697152 N NetWatchDogLinux: initialized network manager connection
2018/01/08 00:10:32.509 7737 139992786697152 N RemoteSettingsMDRelationshipWatchDog: DEVICE ISN'T A MANAGED DEVICE
2018/01/08 00:10:32.509 7737 139992059844352 N RemoteSettingsStore: Cleanup all policies.
2018/01/08 00:10:32.509 7737 139992786697152 N RemoteSettingsStoreListener: Establish connection.
2018/01/08 00:10:32.510 7737 139992059844352 N RemoteSettingsStore::LoadLastReceivedPolicies : Storage Entry Remote_Settings_TVClientSetting_Policy empty
2018/01/08 00:10:32.510 7737 139992786697152 N Using IPC-Port 5940
2018/01/08 00:10:32.510 7737 139992059844352 N RemoteSettingsMDRelationshipWatchDog: DEVICE ISN'T A MANAGED DEVICE
2018/01/08 00:10:32.510 7737 139992786697152 N Updated sessions:
2018/01/08 00:10:32.510 7737 139992786697152 N UpdateOnlineState newOnlineValue 0
2018/01/08 00:10:32.511 7737 139991422326528 N Using systemd-logind for suspend/resume monitoring
2018/01/08 00:10:33.046 7685 139980245552256 G Logger started.
2018/01/08 00:10:33.046 7685 139980245552256 G Found 0 core dump files ...
2018/01/08 00:10:33.047 7685 139980245552256 G systemd: logind service available
2018/01/08 00:10:33.049 7685 139980245552256 G systemd: New seat seat0 [path=/org/freedesktop/login1/seat/seat0, activeSession='c1', canGraphical=1, canTTY=1, canMultiSession=1]
2018/01/08 00:10:33.049 7685 139980245552256 G LogindSessionInfo: New session LogindSessionInfo [id=c1 user=darwin state=user active=1 reliable=1 infoId=1591159457] [path=/org/freedesktop/login1/session/c1 TTY=tty1 seat=seat0 display= vtnr=1 owner=[SysUser: darwin [uid=1000, gid=989 home=/home/darwin gecos= shell=/bin/zsh]] idle=1(1515325702526228) active=1 type=tty class=user state=active timestamp=1515325710017432 service=login defaultCG= leader=755 audit=0 remote=0 rHost= rUser= killProc=0]
2018/01/08 00:10:33.051 7685 139980245552256 G SysSessionInfoManager: observing sessions from logind is marked as reliable
2018/01/08 00:10:33.051 7685 139980245552256 G SysSessionInfoManager: Session Information provided by VT [priority: 2]
2018/01/08 00:10:33.051 7685 139980245552256 G! FrameBuffer: Cannot access /dev/fb0, frame buffer support unavailable
2018/01/08 00:10:33.052 7685 139980245552256 G SysSessionInfoManager: own session cache set to '4294967295'
2018/01/08 00:10:33.052 7685 139980245552256 G Running on Qt 5.10.0
2018/01/08 00:10:33.066 7685 139980245552256 G Initialised XRandR extension 1.5 (base=89 error=147)
2018/01/08 00:10:33.083 7685 139980245552256 G MonitorInfo: [XRandR 1.2] CRTC eDP-1 [email protected] [0, 0, 3840, 2160] - 1
2018/01/08 00:10:33.083 7685 139980245552256 G MonitorInfo: [XRandR 1.2] CRTC 1 has no outputs
2018/01/08 00:10:33.083 7685 139980245552256 G MonitorInfo: [XRandR 1.2] CRTC 2 has no outputs
2018/01/08 00:10:33.083 7685 139980245552256 G Virtual Desktop [0, 0, 3840, 2160]
2018/01/08 00:10:33.084 7685 139980245552256 G!! MonitorInfo: WorkingArea: Property error 14 (0), Errorcode=11
2018/01/08 00:10:33.090 7685 139980245552256 G InterProcessBase::SecureNetwork created
2018/01/08 00:10:33.092 7685 139980245552256 G AutoLogin::Login: enabled: 1
2018/01/08 00:10:33.092 7685 139980245552256 G WindowsSessionStateManager(0x18d1540) state 0
2018/01/08 00:10:33.093 7685 139980245552256 G!!!Own session could not be resolved, unable to startup, Errorcode=11
2018/01/08 00:10:33.093 7685 139980245552256 G!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 5 failed with error 2, Errorcode=11
2018/01/08 00:10:33.093 7685 139980245552256 G!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 6 failed with error 2, Errorcode=11
2018/01/08 00:10:33.093 7685 139980245552256 G!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 9 failed with error 2, Errorcode=11
2018/01/08 00:10:33.093 7685 139980245552256 G!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 10 failed with error 2, Errorcode=11
2018/01/08 00:10:33.093 7685 139980245552256 G interprocessbase::SecureNetwork destroyed
2018/01/08 00:10:33.095 7685 139980245552256 G Shutting down System DBus
Result of checking dependencies:
$ ./tv-setup checklibs
-=- TeamViewer tar.xz check -=-
In order to use the tar.xz version of TeamViewer,
you have to make sure that the necessary libraries are installed.
Writing raw output to /home/darwin/Downloads/teamviewer/logfiles/DependencyCheck.log
Analyzing dependencies ...
All dependencies seem to be satisfied!
Just for the sake of keeping all our ducks in a row … I started a thread about this a few weeks ago.
I believe this fellow was also looking for this functionality. There may be a few others spread out here in the forums … and who knows how many "in the wild." No word from TV that I've seen, but hopefully it is on a 'to do' list somewhere.
Same problem here.
TV13, TV14... doesn't work, no missing libraries with checklibs.
I am using Lightdm and i already tried enough...
I need TV which just works on ANY Linux, Windows, Mac around me without ANY aditional work. It is simple, i will not buy new version (or pay subscription) until this will be simple, solved and just working again.
Sorry for short answer, but my more detailed was lost and i don't have time write it again.
