[Linux] v14.1.9025 (Full) - Change Log
We released a new version of the Linux full version
Operating system: Linux
Version: 14.1.9025 (Full)
Release date: 2019-01-22
Change Log:
- Minor improvements and fixes
And of course all updates from the TeamViewer 14 release:
When will the Meetings feature return? I have not seen any news about it since it was removed from the v13 release.3
Any update on the bug present with using putty on Linux? A large portion of my work requires that I use putty.
This workaround was suggested but I have also been told the same bug was fixed in Tv13.
"If you're having issues using putty through Linux, please use the following workaround.
PuTTY (Terminal -> Features -> Disable application keypad mode).
Then try again, please let us know if that fixes your issue."0 -
Any news about *.tvc file support?
This feature was removed with native linux support but is mandatory for our work with teamviewer.
Please fix this and please communicate with us, when we will be able to use this feature under linux again!
I have the same question. It's very important feature0
