Screen Sharing not working with iOS 12
Strom84
Strom84 Posts: 1
Wanted to try out the screen sharing on my iPhone X (iOS12) from my Macbook Pro (10.14.3 Mojave) I can connect to my phone and chat, but can´t get the screen sharing to work.
It only record the screen and saves it to photos.
Followed this guide:
https://community.teamviewer.com/t5/Knowledge-Base/How-can-I-share-the-screen-on-my-iPad-iPhone-with-TeamViewer/ta-p/4734
  • Kuppo
    Kuppo Posts: 11
    If you are the first time user of the app then make sure to check the below steps once the screen recording app added in control center,
    1. Once the connection is established with other person, don't click on start broadcasting icon in TV app.
    2. Instead slide up control center and 3D touch / hold on the screen recording icon. This should open a pop up showing apps to use for screen recording. In this select TV Quick Support.
    3. Now go back to TV app and click Start Broadcasting. Make sure TV app shown up and selected and then click start to share your screen.
    Hope this helps you!! thanks!!
