Update Version?
I currently run version 7 (XP, as our software only runs on XP for now) on all our machines across the country. I know if the machine has been updated to version 14, I can't log on remotley on my computer using verison 7. What happens with the reverse. If I update my version to v14, and leave all our machines with version 7, can I log on via version 14 to machines running version 7?, or do I have to update all machines to version 14.
  • Comstall
    Comstall Posts: 2
    Thanks Yuri, appreciate your prompt reply.
    I know XP is no longer supported, however I don't need it to be as I only need it to run my software, without updates. I am working on new software that will run on newer versions of Windows :)
    Brett
  • Hi everyone,
    I have used TeamViewer for a long time but I just had a problem with connecting in different versions. I could not connect from version 14 (ubuntu 18) to 12 (ubuntu 16). I am not a super user in the old version computer, so I am wondering how could I connect to it?
    Thanks in advance,
    Rebeca.
  • efect2000
    efect2000 Posts: 5
    "I apologize for any inconvenience caused." ...HAHAHAHAHAHAHAHAHAHAHA
