setting up remote access (mac)
nickcohenkog
nickcohenkog Posts: 2 ✭✭
I know this is probably a real basic thing for most of you out there but I am stumped. Can anyone help me set up remote access so I can wake up a sleeping mac and access my work desktop remotley from my phone or other laptop?
The sleeping mac is an imac desktop running 10.11.3, 4GHz itel core i7, 32 GB.
I want to be able to access it from one of 2 different macbook pros or iphones.
I've installed the relevant software and have been round in circles with instructions getting nowhere! Would really appreciate some guidance. Thank you.
  • Scotty
    Hi nickcohenkog,
    Thanks for your post!
    Could you let us know if you are trying to connect from inside your network or outside your network? I ask as connecting outside your network requires a form of public address and also some port forwarding that can get quite complicated.
    We do have a manual for Wake-on_LAN here as well:  https://www.teamviewer.com/docs/en/TeamViewer-Manual-Wake-on-LAN-en.pdf
    Thanks again,
    -Scotty
    Senior Moderator
  • nickcohenkog
    Hi Scotty,
    Thanks for getting back to me.
    Yes, I need to connect from outside my network (i.e. I want to set it up so my partner and I to be able to access our studio computer from our laptops or phones from home or on the road). I already have the wake-on LAN manual but thanks anyway. I have been through it extensively and had no joy.
    Many thanks for your help and advice.
  • Alrightchief
    This is my exact problem also! why hasnt anyone got back to you?
  • vilas
    vilas Posts: 4
    You need to select both TeamViewer and TeamViewer_Desktop in
    --> Settings,
    --> security & privacy settings,
    --> Accessibility
    on MacBook pro (Mojave) then it will grant remote access.
