Host computer freezes a few minutes after connection.
cjones7999
cjones7999 Posts: 2
I can't find any info in the windows event viewer other than the unexpected shutdown when I manually restart.
Any ideas on how to diagnose or fix this?
Using version 14.3.4730 on Win10 Home v1809, os build 17763.615.
    Hello @cjones7999
    A new version has been updated today with many bug fixes: version 14.4.2669
    Could you please update your client and see if the bug still occurs?
  • @JeanK I did the update and the computer still froze after about a minute.
    Hello @cjones7999,
    Good.
    Could you please check, if all the drivers of your graphic card are up to date?
    If yes, could you please now test to disable the hardware acceleration?
    You will be able to do this in the Advanced options of TeamViewer:
    I hope this will help.
  • cseals
    cseals Posts: 1
    I am having this same issue. I use teamviewer on a enterprise environment and I have one computer that freezes after 10 sec or so and never recovers. I have updated my end and disabled hardware acclereation and nothing works to fix the issue.
